- Aug 30, 2013
- Thread Starter
- #21
So this is a corsair 250D Case with not alot of breathing room to start with. The rad on the front of the case is for the hybrid GPU which is what needs to stay the coolest imo. I have 2 80mm fans blowing full blast on the back of the case sucking air in, and the CPU rad sucks air out. There just isn't enough airflow from those 2 80mm fans to have both rads sucking air out of the case as i think that would cause temp spikes. Right now the GPU doesn't hit over 52C on benchmarks and i have the it OC'd 75mhz which is about all it will take, but it's running 2012Mhz consistently with no crashes. The CPU is OC'd to 4.8Ghz and will get up to 72-75C under load while gaming, but no higher then that.
And if you are wondering, yes I have 2 fans blowing against each other, which seems counter productive but seems to be working since the CPU rad fan is in the middle sucking everything out. But this setup does cause my CPU rad fans to go full blast occasionally during gaming.
Attached is my idle temps.
