8 Channel Fan Controller
beingben
Okay, So I've recently replaced my 200mm fans with 120mm Fans, and Now have 7 fans or 8 with the Fan off the CPU, So...I'm was looking for your inputs on a good, and not so bad looking either 7 or 8 channel fan controller. Some scary brands such as Nextg and Coolermaster makes one version but I havn't been fond of anything from either of these companies...other then a coolermaster case which I am using.
Thanks in advance.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Sunbeam Rheobus Extreme is a 6ch controller but each channel can handle 30W so you can piggy back 1 or two fans as needed (so long as they arent 220CFM 59db 1.5amp fans LOL).
B
beingben
they were all going to by that fan i should you..not sure what the amps where on it
could i piggy back a 4fan controller for a total of 8 fans?
ezcharlie
Philippines
it depends.
the sunbeam rheobus (regular version) (4 channels)
can handle 20 watts/channel.
the amount of wattage your fan will run will simply be
voltage multiplied by amperage.
so 12v multiplied by whatever amps your fan has on it's sticker.
so you can piggy back 2 or more as long as they don't go over the fan controller's rating.
