- Mar 25, 2002
- Ottawa, Canada
Hi, I’ve got some misc questions about my system please have a go at answering them, thanks.
First, my system:
T-bird 1400
Gigabyte GA-7DXR
512 PC266 DDR – unknown company
ATI AIW Radeon 7500
Soundblaster Live 5.1 Platinum with LiveDrive
40G Maxtor HDD @7200
Sony CD-RW 16x8x40 (CRX1611)
Mat****a DVD 16x (SR-8587)
First question.
Does anyone know if this board is any good for overclocking? I’m not doing anything serious now, but I plan to in the summer with a WC system.
Second.
How hot is too hot for ram? I’ve got the ram voltage set to 2.6 right now which gives me temps from 38.5C idle to 41C under load. At what point should I be getting heat sinks or cooling in some other way? Should I even try going to the highest setting 2.7? How much does it actually improve performance?
Third.
The board has a “AGP 4X Overvoltage Switch.” Right now its at the default, 1.5V. Should I consider playing with this? Would it get better performance out of my card? The card is currently OC’d using Rage3D Tweak to the point where if I go much higher funky stuff starts to appear in game. How much would changing the voltage affect the temp of the card, or would it?
Fourth.
Is what the manual calls “system bus” the same as front side bus? If not how can I find out what I’m running at and how can I change it?
Fifth.
My current frequency settings are CPU: 133, PCI: 33, AGP: 66. The board can go to (140,35,70) or (150,37.5,75). What exactly do these numbers mean? How would changing them affect performance? Should I try changing them with just air cooling?
Sixth.
The board also provides a “CPU Frequency Override” which is currently set at 6.5X.
The manual says this function won’t be available with a locked ratio chip, so how do I know if this is actually doing anything? Should I start playing with this?
Seventh.
Is there any way I can tweak my soundcard? I know I’m not even close to pushing its limits, I just want to know that its limits are way out there. Also, is there a way to switch which output the card is sending a signal to? ie. sending the ‘rear’ signal out of the LiveDrive’s headphone jack?
Eighth.
Any recommendations for things to go on my summer upgrade list?
If you read all of this, thanks.
If you read it and can help me with something, thanks a lot.
First, my system:
T-bird 1400
Gigabyte GA-7DXR
ATI AIW Radeon 7500
First question.
Second.
Third.
Fourth.
Fifth.
Sixth.
Seventh.
Eighth.
