- Feb 16, 2008
- East Coast
- Thread Starter
- #21
Thanks baditude...your ratios are similar on two blocks as one would expect, first is highest, then 2 middle, core 3 is lowest.
max temps XT....68, 65, 65, 63
max temps GTZ..70, 67, 68, 65
Since when I rotate my XT 180, core pattern changes, half block is cooling different then other half. I just scribbled temps down as I was in a hurry to check surface with topograph at work after seeing change...but reflection was not good enough to measure surface topography....then looked at insides thinking there might be some obstruction and found a difference there...need to go back and do few mounts with vertical and 180 vertical with non-lapped i940, just to rule out any other variables.
Though I already answered my main question, my HK performs better than my XT on my lapped cpu (HK was ~3C better than GTZ, so both perform better than GTZ), now interested in why core temp patterns change with XT, and why change again when rotating block 180. Clearly something is different between 2 halfs, and only visible difference is the very different milling channels split right down the middle. Top is small pins throughout, bottom is much thicker and some partially cut, almost like channels in some of bottom half areas that would allow water only one way.
