8120 Overclock with a ASRock 970 Extreme 3
Foopsz
Hey, I'm looking to overclock my amd 8120 to 3.8Ghz-4Ghz I know 4 is pushing it because I don't have the best mobo out their. Just looking to get a little extra out of my 4 year old CPU I have a Hyper 212 Evo coming Saturday.
Do you guys think i can get 3.8Ghz-4Ghz out of my 8120 on a asrock 970 extreme3.
Been playing a lot of csgo and on all low at 1280x960 I get just a little over 100fps and it drops to 70 sometimes. I plan on getting a 144hz monitor so I am trying to see if I can get 144fps atleast on my amd 8120 I also have a GTX 760.
Have any tutorial on how to overclock a video one would be better then a written.
Johan45
There's a guide in my sig. You're right about the mobo but it might handle it
Foopsz
Foopsz
for 3.8Ghz I shouldn't have to mess with the voltage right?
I was thinking of putting the multiplier up only to get to 3.8ghz.
Johan45
Personally I would do it in manual. If left on auto it's likely to overvolt causing more draw/heat to the VRM
Foopsz
Foopsz
I will have to see but it would be manual at least I think because my mobo has a manul option then a multiplier that will tell me like x15.0 and then will give me the Ghz that will give me.
idk yet I get my cpu cooler tomorrow. so I will try it tomorrow.
PetrolHead
The CPU temp is probably not going to be the one that limits you, but the VRM temperature. At some point the motherboard will throttle the CPU, but that point may be above 4 GHz, depending on your cooling. Providing extra airflow for the VRM is a good idea. You should also keep an eye on socket temps when stress testing.
Foopsz
Foopsz
Yeah I can see much of a performance boost yet in csgo really my fps hasn't gone up much.
Johan45
I'd like to add that you say you're getting a new 144Hz monitor? If you go to 1440 resolution as well then your 760 with 2GB Vram isn't going to keep up.
Foopsz
Foopsz
Nah I am getting the ASUS VG248QE Its a 1080p monitor and I game csgo @1280x960
noob_smoke
I ran at a steady 200 fps+ @ 1280x720 w/ a EVGA GTX 560 SC. on cs go.
Did you happen to try to unlock the fps cap in cs go? put into the steam launch parameter "+fps_max unlimited" and then in-game in the console type "fps_max 900"
