8500 Install Problem
mdcomp
Classic Administrator
Just got a new radeon 8500. I tried to install it and it says you need to install the standard VGA driver first. What>??? Can anyone send me the standard vga driver or give me a driver that won't do that?
First the Infinite Loop with a gf3 adn now this!!! i HAVE BAD LUCK!!!!!
Violator
Lower Walton, Warrington
Well first of all, have you completely removed your old driver from the system. And the default VGA driver is built into Windows don't worry. And what driver version are you trying to install?
mdcomp
mdcomp
I am using the driver that came with it and yes I removed the other one completely
Violator
Since you've a dual-boot, which OS are you installing?. And did you set the display to VGA after uninstalling the driver? (i.e. you didn't let the OS install anything).
mdcomp
mdcomp
I am installing it on XP. And I don't know what you mean by the second part...?
mdcomp
mdcomp
I tried the drivers it says I need to install the windows standard vga driver first.
mdcomp
mdcomp
It just goes under unknown devices and it says there was a problem with installation......
mdcomp
mdcomp
Tried just running setup, then tried to download a driver............
The Coolest
Senior Member
In WinXP, try going to the Device Manager. there select the card (the unknown device), click properties, if there should be a Reinstall Driver button, hit it, and follow the on screen directions, like set the dir where the drivers are located. and press next. it should install.
In Me remove all the previous drivers, if u had ATI card do a search for ATI*.* in ur windows dir delete all the file, if u had a nvidia there is such thing as detonatordestroyer, u can find it in www.guru3d.com under downloads, should get rid of all the files that were previously installed...
Then restart the computer, windows will detect new hardware and set it as Standart VGA, will prompt to restart, restart it and then install the drivers
