- May 1, 2003
- Seattle
Anyone ever do one? Was it worth the trouble?
taco_fox said:my top core speeds suck while my top memory speeds are great (306/344). I'm thinking a volt mod might help get the core up higher and maybe the memory even more so.
taco_fox said:I don't know. I don't really trust pencil tricks for adjusting voltages.
But tell me something: are you saying you think you got artifacts because of the volt mod itself, or because you didn't have adequate cooling for the volt mod?
juliendogg said:
the pencil trick worked fine, just a little at a time then check with a multimeter.
and second, i'm thinking both. i believe if i had better cooling, (i've allready upgraded the crap hsf that came on the 8500, but i think the one i slapped on isn't doin much better) i was more interested in the mod for the memory as well, but i'm guessing that's where the artifacts came from. maybe with some ram sinks the chips could take a lil more juice?
my card will hit 310/290 as is. i got no better than that after the mod without artifacts or freezing up in apps.
Originally posted by taco_fox No, he said he used the pencil trick. The article you linked is the way I'm planning to do it.
Originally posted by crusher First post...
Well... when i get a Retail 8500 from Gigabyte i voltmoded the card with a pencil...
312/312 before the mod
324/335 after the mod
The core was cooled by a Thermalright SK6 and some cheaper aluminium ramsinks in the ram...
And there is the best 3D Mark score with it:
http://service.futuremark.com/compare?2k1=5829954
OCOW said:
Hey crusher any links on how to do that mod? Nice easy OC
And.............![]()
