8K7A Voltages running High
Spur31
San Antonio, TX
Has anyone with this board had this problem.
The board is running great. (and fast) Just that I noticed that my default voltages are running higher then the normal high:)
What is the max 1.85
my default says 1.83, and I checked the jumpers again.
I may try and flash the bios to see if it helps.
I wouldn't care but this computer is not mine, so I'm not overclocking it. OF course I did overclock it while it is here and it ran fast and stable. 140 was easy, didn't try over that.
The forums here are Great, good info, and a lot of fun.
Thanks for the help Ya'll.
