8RDA3+ won't boot over 1.775 vCore
ALo
Just got my 8RDA3+ yesterday.
Everything is fine!
Except that I can't boot it with a vCore greater than 1.775. :(
Is this a known issue from the 8RDA+?
Or is it a new "problem" on this version of the MB.
I guess the problem is with the bios or mayby the voltageregulator?
Any ideas for a solution?
8rda3+? I didn't think they were out yet. If you mean the 8rda+ It may be the chip's fault. What cpu do you have in it? Mine's running at 1.975v now and it boots fine. Well, there's the cold boot problem but that's no problem to get around. Maybe try holding the Insert key(right above the delete key) when you turn the computer on. I forget what it's called exactly but that's something epox put on the 8rda/+ that lets you get into the bios when you otherwise can't(barring something serious).
When is the 8RDA3+ supposed to be coming out anyway? How much is it going to cost? I think it's time for an upgrade.
The 8rda3+ is out for sure! :)
In Denmark that is.
I have 5 different xp1700+ DLT's. And since I wrote the last post, I think i learned a bit about the problem.
Tweaking the bios with this board is really hard.
It is very diffent from chip to chip.. Some times there is no problem adjusting the vCore, up to 1.9v. And other times it won't event show the boot screen even at 1.8v.
The best way to acchive high voltages for me, is to set the speed eg. [email protected] and then afterwords change the vcore to 1.9v. Othervise it doesn't seem to be done.
One chip can do 1.9v and other can't do 1.8v.
Yes I am confused :)
I haven't figgured out excatly what makes the diffence, I will return when I got the clue.
And BTW I am not a N00B.. :)
The board is prized as the 8RGA+ here.
hehe got it, my fault!! :)
I removed my shim, it was touching some bridges! :/
Great board, im starting to love it! :)
I've heard the DLT3C's hate high vcores. That may be the problem but I'm not positive.
*edit
nevermind :)
WHOO! Runnin' DLT's at 1.9V? Not a wise move for the long haul....
