90c temps
Cheesy Peas
Rotherham,UK
thats the max staded case temp for a Palominio XP, meaning the cpu will be able to operate at upto ~90C.
This does not mean that the cpu will be stable at this speed, but it will have some functionality, beyond this temp, the internal switches etc will die.
Check out AMD datasheet 24309 for the palominos which have a max temp of 90c
And for the Tbreds, check out AMD datasheet 25175.
These can be found here in PDF format.
Pla
San Francisco, CA
1 of the letters on the first line of the cpu steppings states what is the maximum temp. For some cpus it is 90C and for some (including tbred/barton) it is 80C.
This is the maximum themperature after which the cpu may burn or short circuit. The cpu will certanly crash before reaching this themp.
Most users don't recommend running the cpu over 50C in order to keep it running stable. IMO even up to 60C is ok for short period of time.
Above 60 is risky and above 70C is gambling.
Also these numbers are for the core themp - the surface is usually lower.
altec
polka dot ninja
Doylestown, PA
Most CPU's will not operate stably even in the 60C range. Mine will crap out in Prime anywhere upward of 57C...
OC-Master
Edmonton, Alberta
The E-Machine 1800+ AthlonXP machines are built in Mini tower cases with absolutely no airflow and max temps reach 70c when playing the standard direct3D game.
Now thats insane! Talk about a sweat box!
OC-Master
knownotin
i agree man, try to keep those temps below 60c, you dont wanna risk frying your cpu just for a few extra mhz
