95 upgrade --> full?
AltecXP
I find it a annoying that i have to keep my old 3.1 floppies around to reinstall 95 when ever my old cp crashes is there any way ican turn my upgrade into the full version?
su root
Senior Member, --, I teach people how to read your
Ontario, Canada
I know with win98 and higher you can do a regular install using an upgrade CD. At one point during the install, it should ask to see one of your Win311 floppies.
Not sure it works with win95, but it works with 98 and up.
su root
Ontario, Canada
get yourself a full verson.. ebay's probably got them cheap, but inserting a floppy is the cheapest, easiest solution..
stool
Senior Member
Albany, NY
Don't think you can. It specifically looks for an older version. Just to dump the floppies, you might want to burn them onto a CD.
