9500 Pro /9700Pro ?
From my understanding, when you get a successful mod on a 9500 card, it makes it the same as a 9700, not a 9700 pro. I believe that the reason for this is that the 9500 wont generally reach 9700 PRO speeds. I have a Saphire 9500 modded to 9700 and only get 320/307 OC on it and I think that a 9700 PRO is much higher.
That makes sence ,mine only goes 355/315 with Infineon 3.0 memory.16200 is all I can get so far in 3D Marks,but I want 20000:D
Steven4563 said:
the 9700pro is only clocked at 325/310 so u are not that far off u should try flashing it with a 9700pro bios i could up my ram 30mhz more after
Really I can do that?
Were can I get the 9700 Bios?
Dave65 said:
Is a modded 9500 Pro a true 9700 Pro?
No it is not.
A 9500Pro only has a 128bit memory interface whereas a 9700Pro/NP has a 256bit memory interface. Look at the difference in the memory arrangement on the 9500Pro and 9700Pro/NP. Notice the 9500Pro has the memory chips in a straight line. That indicates a 128bit memory interface.
Your card appearing as a 9700Pro is really meaningless.
But in looking at your score I wonder if you really have a 9500Pro. 16+K is very high for that card.
