9500 Pro mod?
Voodoo_fx
Wisconsin
Do i need to do the mod to open up the other 4 pipelines??
My fillrate in 3dmark2k
988 For single
and 2169 for multi.. does that sound right? for stock speeds?
never mind.. what Bios should I use to unlock the clock speeds? I have the retail Built By Ati card, with 3.3ns Infineon ram.. ?
You already have 8 pipes
I think we really need to make a sticky saying that 9500pro's CAN'T be modded
just asking a quick question, Don't know if you have done anything yet to your 9500pro...
Have you downloaded the 3.4 cats yet to open up your cards clock speeds yet? We have a 9500pro and have done that first and it got us 1500 points on the 3dmark2001 score right away. Here in the last few days we have water cooled the GPU, added heat sinks and a small fan on the Ram, AND although you cant mod a 9500pro according to some, volt moded the card. I guess to me anyway that IS modding a 9500pro. If you like, I will send you the results on this experiment. Oh, we got to 15225 on the 3dmark2001 score when we ran it at 1.7 v w/3.4 cats and increased the fsb to 200 along with our new OCZ el ddr 3500 512 ram. (2X256) dual channel.
See our sig for the specs.
give me a shout if you want the info on the card, we are doing some work on the system now and it will be up and running by this weekend.
Happy Trails
Tweaker and Rad Man!
james.miller said:
1)9500pro's can't be modded.
Sure it can. It can be volt modded, or cooling modded. Since when does modding mean only turning a 9500 np into an 8 pipeline maybe artifacting card?
:p
Well....I thought that it should be understood by now, as many n00bs easily get confused that 9500p's can be turned to 9700's.
What do you mean by opening up the cards clock speeds/
:p
read the first post, then read mine. make sence now?
