WHQLbob said:Ok so I've been reading a lot about this 9500np->9700/9800 softmod and I'm very interested. But I want some opinions, I currently have a PNY GF4-4600 and was considering purchasing the 9500np from allstar but after reading some posts on hardforum.com it sounds like this mod is very iffy. I read you have to have the 9500np PCB that has the memory in a "L" shape like the 9700's do for it to be worth while. If its not in the L Shape then the memory bus won't be 256bit like the 9700pcb(correct?).
Would it be worth it for me to purchase the 9500np from allstar to replace my 4600? Or should I save myself the hassle and get a 9700np Gold Edition that can do Pro speeds for 190-200$.
As it stands right now my 4600 runs very hot, it sucks! Its the hottest running peice of hardware in my system. I've already replaced the GPU fan with the TT copper cooler set & Artic Thermal Adhesive and its still very hot. Its not overclocked mind you.
With the 9500np overclocked to 9700 speeds does it run hot?
Would the 9700np run cooler then the 9500np~Overclocked?
Has anyone that purchased the 9500np from allstar had problems softmodding it? It looks like most people that ordered from allstar have had success stories.
My current 3dmark2001 score is 14,300 w/ a P4 2.4b @ 3.3ghz, 1gb twinmos ram, Gigabyte Sinxp Dual-DDR setup. I _WANT_ 17k-18k in 3dmark2001 I noticed a few of you have scores that high with the 9500np~Overclocked/Softmodded, thats the performance I want.
thx in advance.
torchedlh said:i dont' understand why people dont' just spend the extra $30-40 for the 9500 pro. it already has all 8 pipes opeend, you just need to overclock it via flashing the bios and using a program like powerstrip. i did this and it's running great at 370/340.........
torchedlh said:Anandtech's article of the 9500 was a peice of ****. my 9500 pro can run at 385/345 without problems. i believe those are faster than 9700 stock speeds...
Wam said:
@GravY
Exactly which HSF is that you've put on your card and how did you secure it? I take it you removed the shim from around the GPU? I've already replaced the gunk with some Artic Silver but I've decided to change the HSF now as well.
