9600XT Bios flash?
harryinny3
New York
Can a sapphire 9600XT be bios flashed to make the overclock permenent? If so can someone point me to a howto, and where to get a bios? OR can someone use a hex editor or whatever to change the bios for me? I have riva tuner and under poweruser theres some edits. They are for the OC i have on the card now. Are those the values i would have to change in bios?
I dont like software OCing, so id like to OC the hardware itself.
Any help would be great!
Harry
harryinny3
harryinny3
New York
Thats cool,
But can you point me to a hou to? or an editor?. The riva tuner isnt all that stable, and i know i can get more out of this card.
Harry
harryinny3
harryinny3
New York
Thanks steven, But guess theres no bios for a
9600. But i did DL the hex edotor incase i want to try my own editing.
Thanks again.
Harry
harryinny3
harryinny3
New York
That would be cool, But dont
kill yourself doing it. Right now im fine at stock. But a bios with clocks set higher would be great. Thanks man.
Harry
=ACID RAIN=
Kingwood, TX
Harry, use radedit to edit the clock values. I have a BIOS as well, right here:
http://acid-reflux.game-server.cc/apps/9600xt.bin
I flashed with this BIOS already (I extracted it from my card as well) when i tried editing CAS values for the memory to overclock higher and borked my card until i flashed back over. That being the case, it's a known good BIOS.
The card itself is a sapphire atlantis 9600XT with 128MB ram and a 500 core/650 mem clock value.
harryinny3
harryinny3
New York
Very cool Thanks.
Now, Alls i have to do is do a flash useing the ATI flash utility? If thats the case I have to hook up my Floppy. LOL. Thats cool i was going to hook it back up anyway. So basically i do the flash like i would a 9500NP to 9700? Same steps but use the 9600xt bios?.
Harry
harryinny3
harryinny3
New York
NO
Your XT is already Clocked way faster than a 9700, And you do not have the extra 4 pipes to enable on the XT. So The answer is no.
Harry
=ACID RAIN=
Kingwood, TX
Re: Very cool Thanks.
Harry
Something like that harry. Just type in "atiflash" at the prompt and it'll list your available switches. Generally you'll do
A:\>atiflash -p 0 bios.bin
Where
0 is your adapter number and bios.bin is your bios file.
harryinny3
harryinny3
New York
Cool thanks.
Seems the rage3d tweak just doesnt do the job. I used a Bios editor on the bios you gave. Upped core to 550 and mem is at 350 and saved bios. Will try flash after i figure out how to make bootable CD. That bios is for a 2.8ns memory right? I have the fireblade edition.
Harry
harryinny3
harryinny3
New York
Welp Acid, I have a problem.
I extracted the bios from my card and edited it and saved it. tried a flash 4 times and when i go and do, flashrom -i it gives details on my card. Guess what. The bios is locked. Grrrrr major bummer, so it wont flash. But anthoo, I wrote sapphire about redline. I got a copy and lost the cdkey. They replied in a half hour and gave me a key. VERY cool. I have used this utility all morning. Its a great utility. I like the ease of use of overclocking profiles for each game through the .exe of the game. Its pretty cool that the card will OC when the game starts(to clocks i set) And then unclock after game closes. Ive gotten a good boost with this utility. I bit better that rage and riva.
If you need to know more Shoot me a PM.
Later
Harry
