- Apr 10, 2002
- Racine
anyone mod the heatsink by either replacing it or adding AS3 or something? Do you find that that square plate needs to be removed? For that matter can it be removed? It seems kinda lie a shim or something.... I modded it with AS3 and it now tends to overheat cause the damn shim will NOT allow contact between the core and the heatsink, should I go back to the weak ol stuff tha was on there initially? WHere do you get that stuff anyway? A ton of questions...........waitning for a ton of responses CYA!
