spiritedandy said:
this happend to me i lost 8x and in that smart thingy it said 4x
i know it should not make much dif but it sure did by thousands of pionts ?i could not get it back had to format everything.....it all started with the new 3.4 cat
Had you ever tried installed OMEGA's drivers. They have been automatically disabling smart-gart- which leads to they type of 4x vs 8x agp problem, Even though, that WILL NOT cause a drop in your performance. If you've ever attempted to install Omega's drivers, that is likely why you lost the ability to run AGP8x.
If you have better performance after reformatting, it should be obvious the re-formatt cleaned things up, not the difference between AGP4x vs 8X.
Don't believe me? Run some benchies on AGP4x, and tell me the difference
