- Dec 10, 2003
- Chicago Area
My stock GPU voltage was 1.509 V. I did the volt mod with 10kohm resistor, and now get 1.576 V. The max clock I can get with zero artifacts in 3Dmark03 is 354. I feel that is pretty low. Anything higher and I get snow in test 3, above the windows. Is it heat, or voltage that is likely my limiting factor?
My gpu information is:
R300
215R8CBGA 13F
G24720.1
0235AA
I am planning on doing the volt mod with a smaller resistor to get a better overclock once I get better cooling (maze-4 gpu in the mail).
I pulled off the shim and reapplied thermal grease on the gpu and heatsink. The heatsink is very warm, even during 2d operation.
After doing the Volt mod I decided to check my ref and mem voltages. I get Vmem = 2.945 V and Vref = 1.407 V.
My memory is spec'ed at 350 Mhz with nominal 2.8 V, so I am very disappointed with the performance of my memory. The max I have gotten out of it without texture corruption or checkerboarding in 3DMark03 is 335 MHz. Am I going to need RAm heatsinks or a Vmem mod (both?) to get better performance here?
My case cooling is good, with an 80mm intake at front bottom, an 80mm intake blowing directly onto the video card from the side, and an 80mm exhaust at top rear, as well as PSU exhaust.
Right now I am at 19,000 3dmark01 and 5,700 3Dmark03, and would like to hit 20,000 and 7,000 respectively. Any comments or suggestions would be appreciated.
R300
215R8CBGA 13F
G24720.1
0235AA
