9700p, only 3800 3dmarks?
kestrel
Virginia
Update your intel chipset drivers, re-install cat 3.4 drivers, and make sure nothing is running in the background. You can disable most user-originated processes from the system tray, (except explorer, of course) without causing any problems.
Those are your most likely culprits, and I'm betting it's old chipset drivers.
X
Xevuhtess7
Boston Area
i just did a format, i have nothing except my latest chipset drivers, omega cat 3.4, and dx9.0a and im still only getting 4823 marks...
pip
Oregon, The InteLinux State
the prob is you're using the Omegas they are gaming oriented if you want a higher 3dm score I suggest you use the ATIs
X
Xevuhtess7
Boston Area
yeah my bad, the average number i had stuck in my head was 6000 cause i keep reading about people's oc'ed cards, so i was like wow mine is bad..... alrighty, looks like im all set.
bafbrian
Atlanta, GA
I think you should revert back to the earlier CAT Drivers, the older one seems to help you score better than the new ones do, IMHO.
bdw8
Virginia, US of A
Haha 6000, I think o/ced 9800pros are pulling in that. Is your card a 9700pro or 9700np. I see the subject but I didn't know if that is a typo or what.
