9700pro vs 9800se
Yuriman
The OCFORUMS
9800se=4 pipes, 128bit ram. Maybe slightly higher clocks.
9700pro=8 pipes, 256bit ram.
The 9700 will kick the crap out of the 9800se. Your better off getting a 9600xt than it.
Frost Byte
Frost Byte
so, a 9600xt is better than a 9700pro which is better than a 9800se?
thats nuts. But is the info i need.
Basically i'm looking for something in the $200 range
ziggo0
200$? You can get a Radeon 9800 PRO 128meg for that much on newegg. Thats where i got mine.
