- Sep 19, 2015
Hi lads,
Any idea for a 980 ti Kingpin compatible WB?
Really? Is that 30-40 Mhz over your max on AIR? I would have thought it would be more. Tír na nÓg, I use a universal EKWB on my 980 Kingpin and get some good results with it.Water won't really give you that much more headroom on the 980Ti IMO. Even on my chilled loop I can only get 30-40 MHz more
wolfman, the block I use is this one I use a 120 mm fan strapped to the card to keep the Vram cool. Please, keep in mind I only use the Gpu waterblock and 120mm fan for benching purposes only. When using the card for normal usage I have the stock fans hooked up and it works just fine for me.
Pretty sure Johan has a Classy 980Ti
I know that on my 980 KPE witchy they have a tool on the KPE website that will let you rip whatever voltage you want into the card. I've had mine a bit over recommended safe voltages at times.What boost voltage does the KPE run at ?
should be able to find a BIOS that will give you a little bump
If i remember right there are 1.23 / 1.25 & 1.27 BOIS variants out there
does any one know if this water block would work on the gtx 980 ti kingpin
EK Water Blocks EK-FC980 GTX Classy KPE
https://www.watercoolinguk.co.uk/p/...iPq8PBhOX2gJS2zilfRPFiX-EVvgBDhBoCy9kQAvD_BwE
