9800 Pro overclocking
[T-A]_Super_10
Just picked up my 9800 Pro what are some good stable overclock setting with stock cooling.
Please list like this for my Newby agp O/C (only agp :D )
core/mem/voltage:
378/338/1.5v
Akumu X
Near Pittsburgh
Well, I never touch the volts on the thing...and I ain't gonna. Way too scared for that...
my clocks are modest...
441/365(730)/1.5?
Good luck...
edit
bafbrian
Atlanta, GA
I finally broke down and bought one. To tell you the truth, I am afraid to touch any voltage on this card, it costs way to much to fry this quick.
44/360(720)/1.5V(<--- Stock voltage ???)
I am not gonna farther until they come out with a Zalman Heatpipe for this card. Then I will go farther.
SlyJavi
San Jose, CA
I had a Visiontek Xtasy 9800Pro for a week and I OC'ed it in my Gaming Rig you see in my Sig before returning it. It was stable with no artifacts at 450/720. I applied Arctic Silver III to the Core and was able to get a stable OC of 456/720 with a 6453 3DMark03 score and an 18031 3DMark2001se score. Have fun OC'ing. :cool:
T
[T-A]_Super_10
That big of a overclock almost does not seem worth the time and effort. I am getting around 16670 almost everytime but if i jump the CPU up to 2300Mhz instead of 2200Mhz i can break the 17000 mark without overclocking anything but CPU. I wonder if i overclock ram, video and set CPU to 2300 wonder what i can get?
Oh 1 last thing my CPU is 333FSB and my mobo is a 400FSB and i have it set to 400(200 in bios) should i disable my FSB Spread Spectrum it is set to .5% at defalt. Thanks again all
JasonBr
Disabled
St Louis
The volt mod is real easy, im about as talented as a one armed monkey with a soldering iron and i did my mod on my 9700pro
My 9700 Pro is running at 461 core yes 461 =) [1.72volts]
BaD CrC
Belfast, Northern Ireland
Got the ATI 9800Pro. GPU watercooled with Innovatek WB and AS Ceramic, RAM with Tweakmonster HS and AS Epoxy.
GPU set to 450 Mhz
RAM set to 360 Mhz
I got 3DMark03 latest at 6540 points with P4C3.0Ghz @ 3.3Ghz.
I haven't tried to run 3DMark03 without CPU o/c though so I don't know if it's worth to push the gc.
BaD CrC
Lol.
Just checked Futuremark hall of fame.
There's a guy there called **OPPAINTER** with 25676 point 3DMark01.:eek:
It seems like he vapochilled his 9800Pro so he could crank it up to....... 567/418 !!!:eek: :eek: :eek:
P.S: Not to mention his P4C 3.0Ghz @ 4.2Ghz.....:rolleyes:
Morbid
Nitpicker
Dallas
OPPAINTER is notorious for having one of the highest, if not.. THE highest, overclocks without going the extreme measures. By extreme I mean, dry ice and LN2. That particular setup he has is a Prometia cooled CPU and Vapochilled 9800 Pro.
I'm pretty sure he gets sponsored, otherwise the guy just has too much money ;)
qwerty57
BANNED TROLL-Silversinksam
OPP is not sponsered from what i know and his setup looks very very plain a case with all parts in it drives ext. with the prommy heads connecting to the cpu and gpu.... for the best he sure doesn't have a rig that looks like it :)
Akumu X
Near Pittsburgh
OPP for sure isn't sponsored by anyone. I'm a member of the xtremesystems.org forums. MSI won't send him anything and I think he gets very little "for free" he must just make really good money. In 3DMark him, JCViggen, Macci, and DJ are all crushing people. Guess they all got alot of money....
T
[T-A]_Super_10
BaD CrC
where did you find a waterblock for the 9800 Pro at (innovatek) all i can find is the 9700Pro waterblock
water_cooler 20
FL, USA
I wonder if my R9800 256 with a cascade water chiller will beable to bet opp.Cpu will also have a cascade direct die.
