Well you will most likely want to just flat out reinstall windows so there is no chance of past drivers on there. and you would like to use the latest catlyst drivers
You need to uninstall your current nvidia drivers and the run driver cleaner to pick up what it left behind. Click here to download it
It does have a readme with it. So read it to figure out how to use the program properly.
Quattro: Just download a driver remover from a site like www.guru3d.com ... install it, and follow the instructions.. there is no need to re-install Windows
