9800pro flashed temps
HousERaT
Senior Air Extraordinaire
Imladris
Hello all you lucky ducks with 9800pro's flashed to xts....... what are your temps like?
Mine shows 55°C at idle and 62° at load.... I'm running mine with a VGA Silencer/ramsinks...... are these good temps?
HousERaT
HousERaT
Imladris
it has to be a 9800pro on a xt pcb........ some of the ones made by Sapphire and a few others have the temp chip built in..... sorry :-/
actually yours might be one of the new ones..... you got a r360 core?
dreIU
Bloomington, IN
It is a R360 core, but it apparently is not on the XT pcb... oh well, if it fries it fries :D Just means i get my x800 xt sooner .
