9800pro Softmod-Help Needed
drydog
MO
9800pro Softmod-THANKS
Hi All;
After trying my fourth floppy disk of the day and renaming my bios, I finally achieved myPro to XTsoftmod. I do appreciate everyones help. I will let you all know my results next week. I don't plan on doing any over clocking until I get rid of the stock fan and heatsink.
Respects
Bill
I am very new to the OC'ing world. I have been picking up some new info since I found this board.
I have followed the instruction on the "How to Softmode" thread. I have a Raedon 9800pro Atlantis 128 MB. For some reason I continue to get the OFLO1 error message during the flash.
If anyone has any suggestions on how to fix this, please let me know.
Thanks
Bill
What bios are you flashing it to?
Will it do teh clocks that are stock with that Bios?
I would also try redownloading the BIOS, perhaps it got corrupted during the download?
I have used both the ATI9800XT.128mb.Samsung.E-die and the HIS.9800xt.128mb.samsung.bin
rename the files to something like atihis.bin something short or you mite need to do something like
ATI9800XT.12~1.bin or whatever shows up when you type dir in dos
update
First off, thanks for the reply's.
I am still stuck with the above mentioned error. I have changed floppy's and down loaded all of the files 3 times.
This is the command I am entering when I attempt to flash:
flashrom -p 0 HIS.9800XT.128MB.Samsung.BIN.
When I attempt to go into the Flashrom folder on C:, It does not recognize the C drive.
I will keep going until I figure this out.
Thanks again for the help.
Respects
Bill
update
Hi;
I took out the card and looked on the back. This is the info I found:
Hynix
HY5DU283222A
F-28 402A
W7CD4819FQ
What other info can I find that would be helpful? Also, besides taking of the cards heatsink and fan, is there any other way of finding out if I have a 350 or 360 core? How hard is it to do this and put it back on? Will I need to apply a thermal paste?
I tried the ATI flash V1.3. This is what it told me:
Serial ROM
BIOS device ID=0x4E4A
ASIC device ID=0x4E48
Asic ID does not match with bios file, use -f to force flashing.
Is this a good idea?
Thanks again for all of the help.
Respects
Bill
ehh, i have the same ram. well i have been told that r360 has a springloaded heat sink. but yeah. you can try, if you fail, u can always reflash. i have not used ati flash but of course the bios is not going to match, haha, just force it. if it fails reflash
