- Jan 9, 2006
So I happened to notice my 9800x3d was hitting the mid 90's while gaming. Thinking I must have screwed up the thermal paste I took my noctua d15 off and the paste looked spread just right from edge to edge without any extra. Just right. I went into the bios to look for an "eco mode" or lower tdp mode and saw it was on auto with the next choices down being 170w then 120w and 65w iirc. I tried 120w tdp mode and restarted then fired up oblivion remaster to play for a few minutes. Now my max temp was around 76c but the cores still show 5200mhz max in hw monitor like nothing had changed. I googled it and apparently 120w is actually the normal tdp? I guess that means that msi had it defaulting to melt without water cooling mode unless I'm not getting it. Am I on crack?
EDIT: I did a cpu-z benchmark in 120w tdp mode and did a submit and compare on their website. My cpu was right where it was supposed to be compared to the other 9800x3d on the chart in single and multi threaded scores at 5200mhz per core. Something about the default settings on my motherboard was adding 20c to load temps for no apparent reason
Looks like I have to learn more about amd. Glad I noticed it!
