First time overclocking one of the (newish) i7 chips, and I've got lots of questions (thanks in advance to the incredibly helpful and patient people on this forum!)
I've already read the stickied 3-step guide to iX overclocking, and its answered most of my questions as to how i7 overclocking is different than the last few chips I tried to fry
Sooo...most of my questions are related to what people have been seeing performance-wise for this particular CPU (I tried searching for 980x in thread titles, and I'm sure this information is out there, but I couldn't find it in the two pages of results that came up).
First, some partial system specs:
980X on watercooling (AK Supreme HF), hyperthreading enabled (because, well, why not)
Rampage III Extreme MB
2x G.SKILL Trident 6GB (3 x 2GB) DDR3 2000 RAM F3-16000CL9T-6GBTD (12 GB total RAM, registers at 1066 with MB settings on auto but is designed to be overclockable to 2000)
3x5870 on watercooling, other assorted parts that shouldn't affect a CPU overclock (I'll overclock the GPUs next, but one stap at a time)
As far as use goes, I'll keep the computer on 24/7, use it daily, and it will probably be folding (whenever I actually remember to start the threads) when I'm not using it.
Now, questions!
Overclocking questions:
1. The guide mentioned on i7 chips I should try and find the max bclock first, and then mess around with the multiplier. I know that on other unlocked multiplier chips in the past, some people have gotten better performance with very low blocks and high multipliers - is this a better option, or should I stick to the testing order in the guide? (max block, then increase multiplier until temps and voltages get to the limits)
980X specific questions (i.e. what have others found while testing?):
1. What's the maximum 'safe' temperature for 24/7 use on the 980X? Qxxxx chips can be little heat factories, and are safe at 90C. AFAIK, doing this with the i7s is a bad idea. What should I stop at here? 70C (although that seems extremely conservative - maybe 75-80C would be better)?
2. Voltages: What are the maximum safe voltages on this chip (going by the intel spec sheet is one option, as always, but going by what forum members have found through testing is always better ):
Vcore: (not sure what's a good maximum here, although the watercooling should help poke it up to a tiny bit more than an air setup)
QPI/VTT: (I've heard that the i7 chips have not-so-great IMCs, so no clue what to use as a max here):
Memory questions:
I'm guessing I probably want to follow the recommended manufacturer specs: 9-9-9-24, 1.65V, as close to 2000 as possible.
Should I bump memory voltage up a bit to maybe 1.7 or even 1.8, or will that likely result in frying? The Gskills are designed to OC quite high, so there may be a bit of wiggle room here (on the other hand, ram is easy to destroy)?
Video cards questions:
I'll do the CPU and memory first, then post video card overclocking questions in another forum if needed - OCing video cards is generally much simpler than CPU/memory anyways)
If I can get the CPU to 4.5Ghz, I will be absolutely estatic (and shocked). More realistically, 4.0 is my 'minimum acceptable standard', and I'll be quite happy with a final OC of 4.2-4.3; we shall see what I get...(I'm also hoping for a 33% video card increase given the temps I'm getting on water and the OC tests I've read, but that's a different step)
Summary:
a) what's the max temp I should keep the CPU at under load?
b) What's the max settings I can use for: VTT, VCore, Memory
c) Do I want a high block and then increase the multiplier, or do very high multipliers work better?
Thanks for the help!
Zithras
Now, questions!
Memory questions:
Summary:
Zithras
