some of the blank media is dvd+r some is dvd-r which is a byproduct of the format wars. just get one with both and you'll be able to burn just about any dvd recordable (except dvd-ram).Andy71600 said:im new to dvd-burners, and i am thinking about picking one up. My only question is wtf is the +/- thing?
There are four media types supported by drives of this type. DVD+R, DVD-R, DVD+RW, and DVD-RW. The "-" formats are an older specification for drives and media, originally supported by Pioneer, amongst others. The "+" formats are a newer specification supported by Philips. Both formats work in most home players, but there are no guarantees. DVD-R works in a few more really old players, but just about anything sold in recent years will play +Rs and +RWs.Andy71600 said:im new to dvd-burners, and i am thinking about picking one up. My only question is wtf is the +/- thing?
what a great salesman.. lollarva said:DVD-R media has a slightly better compatiblity rate in testing with home DVD players, but most anything recent will play either.
I'm not up on the exact technical differences between +R and -R media, but +R media does lend itself more easily to high burn speeds. This is why the 8X drives prior to the new NEC only burn 8X on +R media. The NEC is the first to allow 8X on -R media. Likely faster burn rates than 8X will be the sole domain of +R, but even that remains to be seen.
So in short, burning at 4X, I don't know of any pressing advantage to using +R over -R, unless your drives or home players show a preference for one or the other. The NEC 4X burn flawlessly on either with the modern firmwares.
big difference between a 2x cd burner for 400 dollars and a 4x dvd burner for 100.cstarritt said:i think im gonna wait a bit more before i buy a dvd burner
i made the mistake of buying a 2x cd burner back when they were $400 and i plan on waiting till they get a bit lower first
you are quite correct about the hd/burner issue. i hadn't thought of it that way.Mr. Chambers said:thank you for the clarification larva.
as for you Maxvla, if you got a burner, you wouldnt need that huge HD, and new speakers for your backup rig? man my backup rigs dont even *have* speakers
