- Jan 10, 2019
Hello
since i kind(a) messed the other thread i would like to give me yuor opinion about my results and and opinion about my issues.
i recently upgrade my desktop.
Some info about it.
Intel i9900K
Gigabyte Z390 Aorus Master
MSI 2080ti Gaming X Trio
G.SKILL Trident Z RGB F4-4133C19D-16GTZR
My m/b wasnt able to read those dimms. I made the mistake to buy a non listed memory. I heared that some times gigabyte works better with 4 dimms, so i bought another set (used) since i got it really cheap from a local guy.
I managed to get memory to play at 4000 18 18 18 38 1.4v (vccio and vccsa at auto but looks really high (?))
I have run Memtest Pro 1000% and Memtest86 (2x10 runs) with no issues at all.
Cpu is at 5000 with no offsets at 1.33v.
I run Prime95 Small 26.6 for 8h with no issues at all. I even tried Aida but no problem as well.
When i am playing BFV i get random game crashes. I tried to play with one set of ram but then i got blue screen (memory something).... With 2 sets (4 dimms total) i had no blue screens.
I am also waiting for a new riser calbe since this might be the problem (>) not sure...
@Woomack /any
I see that you always saying that in games you wont gain anything above 3200-3600. Do you suggest me to try get 3600 15/16 for high demanding games?
I am using my system only for gaming and small normal tasks.
Do you see something wrong on my settings?
Any opinion will be much much appreciated.
Thanks
Some info about it.
Intel i9900K
@Woomack /any
Thanks
