a curious question about P4 temperature
tutrinh
It may be silly to some, but I really want to ask, I haven't try it yet but maybe some of you do.
Which will have a higher temp??
P4 [email protected] @1.52V
or P [email protected] @1.6V
My mainly concern is : Is the speed that make the CPU hotter or the Voltage that make it hotter.
TC
Senior Seti Addict
Denver, CO
Well technically both voltage and core clock generate more heat, but in the above example you have them running at the same speed, so the one with more voltage will run a little hotter.
T
tutrinh
Let put it this way.
If 2.53 @ 3Ghz @ 1.5V is still cooler than
2.53 @ 2.7Ghz @ 1.6V???
thanks
