A different way to test memory bandwith....
Jess1313
now adays you see every one using sandra to test memory bandwith...dont get me wrong, it does a good job at it, but check out this program i have, i found it back when i was messing with k6-3's and stuff. it usually showes ram bandwith slower that sandra, but is more responsive to tweaks, is a lot faster to run, and gives you a graphical display of read(green i think) and write(red i think). give her a try and tell us what you scored.(BTW DO NOT SET PRIORITY TO HIGH, YOU WILL CRASH ;) )
  • bm128.zip
Jess1313
Jess1313
heres a screenie of my [email protected]@3-4-4-8-2t timing, not so good, give me a min or so and ill get one of my shuttle in my sig posted...
BTW=sometimes CPU clock isnt accurate...
Jess1313
Jess1313
my shuttle :cool:
falcx
Regina ,Canada
Heres what mine is at.......I kicked my fsb back to stock and have my timings at 2.5-3-3-6. Rig is in sig. Running 2 sets of 2x256 Kingston Value Ram DDR400.
Drec
weeee my cheap *** ram
Jess1313
Jess1313
thanks guys. wow the p4 seems really smooth compared to the Athlons...
keep em coming.:)
disk11
Charlotte
Specs since I haven't updated my sig for some time, all hardware the same:
215*8, 2.5-2-2-11
Jess1313
Jess1313
amazing how similar the barton curves are
thanks for testing guys...
FTC
Barcelona, Spain
Something wrong with laptops... my centrino 1.5Mhz w/DDR2100 CAS2 mem gives averages of 60Mb/sec with this tool (expected results and confirmed with Sandra should be around 2000Mb/s)
Regards
FTC
Jess1313
Jess1313
Regards
FTC
humm im not sure there i have used it on about 11 or so comps. usually if sandra is about 2000, it shows about 1,500mbs. but it usually responds well to adjustment.
Jess1313
Jess1313
Tedinde said:
Tried it on my AMD64 rig. I get the same scores weather im @ 200fsb or 250fsb??
well is you mem bus, running the same as your htt? or are you running a ratio, if you are do you use the same mutltipier at 200 as you did 250?. a64's are really weird, sometimes the multiplier can afect ram mhz.
look in cpuz under the memory tab. under ratio, sometimes it shows it being, for exaple cpu/12. or cpu/14 or such as that. with "cpu" meaning "cpu multipier then it it was cpu/12, and you had a 10 multuplier then you would have a 10/12 (5/6) ram deviser, then if you changed to an 8 multiplier then it would reduce the ratio to 8/12 (2/3) effectively lowering your ram mhz.
:D
p.s.=Tedinde, your the one with the k8n neo PL over at xtreme arnt you?
check and see what its are and report back
thanks
Tedinde
Xtreme refugee
Wilmington DE
Same multiplier 1:1 250fsb or 1:1 200fsb I just tested @ 280fsb 1:1 2800mhz Sisoft scores go up but this stays the same
Jess1313
Jess1313
I thought this to be very strange but I tried what you said & you where right.
I figured it out though & you are using the refresh buton & it has to be closed & then reopened. Strange though.
It doesnt do this when changing mem timings just when changing FSB.
Jess1313
Jess1313
Youll notice the #s on the left are usally close to what sandra reads.
I use the prog for setting up because its quicker than sandra & then after I get where I need to be I run a sandra.
That P4 score is insane :attn: .
Yamiyanazz
Oregon
2500+ @ 200x11
Asus A7N8X rev.2
OCZ PC3200 256MB x 2 matched set
