Im planning on getting a new setup soon and so far this is what I have:
Gigabyte DS3
C2D E6300 -or- E6400
1gb of ram
Now for the string of questions...
-1 stick of 1gb or 2 sticks of 512? I ask this cause later i will get more to get up to 2gb so I wonder if it will be best tolater have 2 sticks or 1gb or 4 sticks of 512.
-What speed ram should I get? I was thinking ddr2-800 with the cl4 timings. From what I have heard, ram could overclock more if it is rated at cl4 because you can slow down the timings to 5 and get more mhz out of it. Is this true? or would I be just as good off with the cl5 timing ram.
-I heard that with the E6300 you need good ram in order to OC it well because the multi is low. So with the E6400 I wouldnt need ram that was as good?
I dont plan on harcore overclocking, I just wanna have some fun! What would you guys do? Any suggestions? Thanks!
PS: another Q.. you cant increase the multi on c2d chips can you?
Gigabyte DS3
1gb of ram
