A few questions on OC an V3 2000
SoNgOkO
my computer chair
Ok i finally have some time to OC my V3 2000. I dl some software that worked ( i tried at least 5 progs but no1 could find my GFX card ) I have an blue orb on the v3 and i am wondering how much is the max OC for the current card setup??? and how much at a time should i raise the GPU speed??? Will i be able to OC more if i would put an fan on the back side of the V3 and memory HS?????
THANX
DeRose306
Clinton, AR
I still have a old V3 2000 in a seti cruncer. If I remember correctly, I OC'ed it by reflashing the bios with the 3000 bios, and added a fan to the Original GPU cooler. I don't remeber the actual #'s anymore, but I do know that ram sinks didn't help me any at all. I went nuts and tried to overclock the GPU more that 3000 specs, but I didn't seem to get very much further. The big advantage of using the bios is it's pemanent. unless you flash back
ShadowCat66
Oshkosh,WI
I use Voodoo3 Tweaker 2.7 to O/C my voodoo3 3000.I'm not sure if you tried this one but its a nice program and works for me.There are alot of programs on www.voodoofiles.com that you might what to check out.Hope this can help you out alittle.
DDR-PIII
Disabled
6p6
I got my Voodoo4 4500 PCI to 230/230 with some extreme cooling :) but not for very long...
DDR-PIII
Disabled
6p6
LOL and "your" talking about worth less haha
"creative tnt2 ultra 150/183 @ 170/210"
