Hi everyone, I created an account on this forum as I'm looking for some help when it comes to overclocking my cpu as well as gpu (further). I'm not a pro or anything so please don't be too harsh if I don't know something or have done something wrong.
Without wasting anymore of your time, let's get to my setup as it is probably the most important part.
CPU: i5 2500k 3.3Ghz OC @ 4.4Ghz however I have a separate topic when it comes to the cpu as I'm trying to go even further. Here is the link if you would like to also help there: http://www.overclockers.com/forums/...-on-oc-ing-the-i5-2500k?p=7791030#post7791030)
Cooler: Be Quiet! Pure Rock 210
GPU: MSI GTX 970 4G- So far I got the memory to 2003, core clock to 1253, boost clock 1393. The voltage while testing in Heaven 4.0 was on 1.218 (Which I think is a bit odd as it seems a bit higher than what other people have? Especially since I was not tweaking it at all and they were like that from the start while running the Heaven 4.0 Extreme. I'm pretty sure anyway.) The temps were at around 60 degrees and the power consumption didn't go over 90%.
Mobo: AsRock P67 Pro 3
RAM: 2x4GB RipjawsX 1600 CL9
PSU: OCZ 650W
If you need any more information about my setup then I'm more than happy to answer your questions as well as if you want me to do any other tests a part from Heaven 4.0 on the Extreme preset then again, I'm more than happy to do so. Btw. I was using the GPU Z in order to see all the exact values while testing and the MSI Afterburner to do the actual oc.
Now the questions:
1. Is there anything wrong with my voltage? It seems as if it's a bit higher than what other people have. (At least that's what it seems like to me after reading/watching some reviews/overviews, etc.)
2. Is it safe to use the card with that 0db feature on? Or would it better to change it so the fans always spin? (I'm asking because the opinions on this are split and this is why I ask for advice here.)
3. How does that 0db feature work exactly? I was checking it myself and it seems like the fans turn on when temp gets to +/- 55degrees and 30% load? I'm not sure. If it's possible I would like some more exact figures.
4. What are the max. safe temp when it comes to this card? (I couldn't find any info on this, dunno why...)
5. Which clocks can I still go up with?
In other words, what do I need to do (If it's possible to get anything more out of this gpu ofc) in order to get some higher clocks on it. Also, if there are some threads already which answer at least some of my questions then I'm of course willing to go and have a look at them.
Thanks in advance.
PSU: OCZ 650W
Now the questions:
Thanks in advance.
