A cheap relable controller that will handle easily a 200mm fan? or 3 fans on one chanel wired in parellel (standard medium speed fans)?
Good
http://www.jab-tech.com/Sunbeam-5-1-4-Rheobus-Kit-BLACK-pr-2530.html
You can't get cheaper or more simple/reliable than this. very popular.
Better
http://www.jab-tech.com/Sunbeam-Rheobus-Extreme-Black-pr-4090.html
does it come with single 3-pin extentions? I wish the better one came in red leds instead of blue as my case fans are red
Absolutely the best fan controller out there. It doesn't look pretty, but it handles my super high speed 220cfm Delta fans (over 2 amps each) without an issue. Very very few fan controllers can claim that type of control.
Mine did not come with any.does it come with single 3-pin extentions? I wish the better one came in red leds instead of blue as my case fans are red
The NXZT Sentry 2 But it is only 10w per channel...
when you say 10watts per channel, does that mean it can handle a 200mm fan? or like 2x120mm fan per channel?
the slipstream (1200rpm/120mm) is 0.26 amps (3.12w @ 12v) , and not sure didn't have much luck googling the CM haf 922 fan, but it should say on it or you can google if you have the product number...
scythe slipstream for 120mm and cooler master for the 200mm
