I put a 50 mm Delta on a standard Intel HS and that works very well. I tdoes take up two pci slots though so make sure that you have enough space. I also used some silver epoxy from millisec.com that works well too. Just make sure that you have some way to catch the HS in case it falls off so that it does not ruin the cards under it. I used some wire to hold it.
