a little problem.
DDR-PIII
Disabled
6p6
I get this error when i try to flash my firmware with a newer one... it says its unable to delete the firmware.... this is what im doing in dos
c:\firmware "dir"
mtkflash.exe 3 w /b 8480B103.bin
then it shows a status... then the error.... also i didnt not choose to have cd rom support in dos mode i know not to do that... can I delete the old f/w manualy ?
Vovan
Germany
Try to enable in the BIOS firmware upgrade option, disable Virus protection and turn off RAM/ROM shadowing....
