so lets start mates, My current build is :
i5 3470 ivy bridge
asus gtx 560ti 2gb factory overclocked
8gb (4x2 kingston hyperx blue fury)
asus p8z77-v lx
Zalman 650W
ocz agillity 3 120gb SSD
I've build that pc in Aug 2012.
Its time to upgrade, the purchase's gna take place in Ukraine (lowered prices on hardware and stuff) so.. I've decied to go for it, after 3 years :
I was thinking about something like ...
GIGABYTE GA-H97-HD3
Intel Core i7-4790 3.6Ghz
Arctic Cooling Freezer i11
KINGSTON DDR3 8GBx2 1600
Gigabute GTX970 4GB DDR5 GV-N970WF3
650w PowerSupply
Samsung Pro 850 256GB SSD
NZXT Phantom 410 White / Fractal Design Define R4 Black
NO OC PLANNED HERE, STRICTLY A STOCK PC.
I'm gonna add some NOCTUA fans aswell, I really need ur help on choosing the power supply & case (between the two, or if u have any other specific pieces that are just as good)
GPU - the next build MUST have a gtx 970 (just because I dont have enough funds to get the 980, and I HAVE AN ASUS VG248QE 144HZ screen so I need a powerful gpu[/COLOR]
CPU - my mind is pretty much set on the cpu aswell, as its the most efficient one I've found to fit my budget considering its performance. cpu cooling is something I need help with as well, Ive included the i11 as the default choice.
RAM - I guess its time to get a 16GB build, one question tho, are Patriot's Red Venom & Corsair's Dominator platinum with these big *** thick radiators are for OC only ? or is it something I may consider even if not going for one?
MB - after bad exp with the few last Asus mb's Ive bought, I decided to go for a GIGABYTE one, and then found the h97-hd3 to fit well here, any thoughts on that? (AGAIN, NOT PLANNING ANY OC or future upgrade)
SSD - after a great 840 evo 120gb tryout, I think I'll go with Samsung Pro 850 256GB after quite a lot of positive reviews .
Any tips and fix ups will be welcomed and greatly appreciated.
i5 3470 ivy bridge
asus p8z77-v lx
Zalman 650W
GIGABYTE GA-H97-HD3
650w PowerSupply
