- Mar 19, 2001
- Sedro Woolley, WA.
Yesterday I had some rare and unexpected free time, well I have been wanting to try out an idea that I got after reading Hoots cohesive cooling posts and article . I have an old free standing nautral gas fire place that is no longer in use (stored in my shop) It had an dual AC blower in it that put out like an M16 an is fairly quiet (est. 35 to 40 db-a) so I pulled it out and cleaned it up, plugged it in and tested it to make sure it still worked. I went to coast to coast and bought two 4in. x 8ft. lenghts of flexible ducting and went to work first I cut off a small length and attached it to the delta on my sk6 then I attached the other end to the 80MM sunnon case fan (after turning it around to be an intake) I put a filter kit on it and then attached the remaining lenght of ducting to the filter enclosure and ran it to the left side of the dual blower assy. I then ran the second lenght from the right side of the dual blower assy to the filter enclosure of the side intake blow hole to cool the case. I have two fans in my psu and an 80MM sunnon 40 cfm exhaust on top of my case as well as 2 80MM sunnon intakes in the lower front. I pluged the dual blower assy in to a switched surge protecter and turned it on before I turned on my pc I could feel cool air coming out of the top blow hole and the psu exh as well as the lower front. I turned the pc on and let it run for a few mins. Right off the bat I saw my system and cpu temp were way cooler than before this mod after running it a couple of hrs. and running Sandra burn in wizard in loop mode for an hour this is what I came up with.
Previous systemp 78F @ 72F ambient
Previous cpu temps idle 37C Load 45C @ 1.54
1.9 vcore
Current system temp 71F @ 72F ambient
Current cpu temps idle 32C Load 38C
Total out of pocket expense 7.95 for the two lenghts of flexible ducting. I was was real happy with the results for the amount of time spent (maybe an hour) and now I have my rig off the floor and back in the cabinet in my pc desk. I don't know where anyone could buy this type of dual blower unit but I'm sure their still avalible. I'll post a pic of the unit if anyones interested.
Randy
Updated Sig.
1.9 vcore
Randy
Updated Sig.
