a T line question
Toysrme
Just don't fill it up all the way.
The water level will also be sucked down the T line slightly with the pump on and the water rushing under the still liquid.
The moving water creates a low pressure and the water above in the line is sucked down into the loop slightly.
My personal way of sealing my T line involves a plastic thimble and duct tape.
Toysrme
And yes, I don't care what some might think, no matter how good you connect every line, and cap your res/T.
You will loose water out of the system at some rate.
rogerdugans
Linux challenged Senior, not that it stops me...
Corner of No and Where
Anything that closes it off will do.
In one of mine I use an unused valve from an aquarium setup and the other uses one of my fill/bleed kit valves from a Swiftech kit.
Obviously I prefer using valves to ensure that water can't spill, but it is not necessary unless the pc is portable (as one of mine is :D)
