- Sep 12, 2001
- Ft. Worth, TX
The easiest way to cut a hole with a Dremel, is to first concentrate on one small spot. Once you can get through the metal there, it becomes extremly easy to cut out the rest of the hole. Also, don't apply too much force on the Dremel. Push lightly and take your time.
