- Jan 24, 2006
- South Dakota
HowTo: A <very> brief guide to remapping your remote
so after digging and digging and pulling from various sources I finally have this sorted around so I thought I would pass it on
Objective: Push a button on your remote and have it launch a program or execute a command
You need: lirc, irexec and possibly lirc-modules-source
You need to know: where the program bins are located; how to edit a text file
Step 1: plug in your remote, wait several seconds then find out if and how linux is detecting it by using
sample output: lsusb
sample output: dmesg
As you can see I have an mceusb2. This is important for the next step
Step 2: install what you need
Select your model of remote when prompted by lirc
Step 3: type
to test to see if your remote is working. If its working, as you push buttons it will spit out jibberish in response to the keypress (well its not jibberish but you get the drift)
Step 4: run
this will generate .lircrc and .lirc/ files/folders
Step 4: create a link inside the .lircrc file it should look something like this
Step 5: create the file .lirc/irexec (choose your favorite editor... i like nano)
Step 6: insert the code into the irexec, save and exit. The code looks like this
where remote is the remote which you have and the config file is what you want the computer to do on button press
Step 7: restart lirc and manually start irexec
Test your buttons. If it works, great your pretty much done, you just need to add irexec to your startup
System->Preferences->Startup Applications if you are using a gnome desktop
or Applications->Settings->Sessions and Startup if you are using XFCE
(sorry I dont have KDE on any computers)
There you have it.
Any problems just post back
Code:
lsusb
dmesg |tail
Code:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 1784:0008 TopSeed Technology Corp.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Code:
[ 6.646188] lirc_mceusb2: Philips eHome USB IR Transceiver and Microsoft MCE 2005 Remote Control driver for LIRC $Revision: 1.44 $
[ 6.646191] lirc_mceusb2: Daniel Melander <[email protected]>, Martin Blatter <[email protected]>
[ 6.938644] lirc_mceusb2[2]: Topseed Technology Corp. eHome Infrared Transceiver on usb3:2
[ 6.938671] usbcore: registered new interface driver lirc_mceusb2
Code:
sudo apt-get install lirc irexec lirc-modules-source
Step 3: type
Code:
irw
Step 4: run
Code:
mythbuntu-lirc-generator
Code:
~/.lirc/irexec
Code:
sudo nano ~/.lirc/irexec
Code:
begin
remote = mceusb
prog = irexec
button = RecTV
config = /usr/bin/xbmc
repeat = 0
delay = 0
end
Code:
sudo /etc/init.d/lirc restart
/usr/bin/irexec -d /home/$USER/.lirc/irexec
There you have it.
