a virus i cant get rid of!
google search for "mcafee ssdrop" or "norton ssdrop" to look for a solution.
I use the mcafee stinger to fix some particularly difficult viruses, and it's free. (I don't know if ssdrop is on it's list though)
www.sarc.com and look it up...this is the website I go to whenever I find a suspicious looking file on my comp, or a friend finds a suspicious looking file. It will tell you what it is, and it will usually give you removal instructions.
oddly enough, I cant find any info on it on SARC. Also, a google search reveals that it appears to be a p2p virus, but I cannot seem to find any good info on it. a bunch of german and eastern european sites mostly, or pr0n sites using it as a search term.
