AMD said:Added AMD Sempron™ Processor and Mobile AMD Sempron™ Processor chapters.
Removed model 3100+ 62W OPN.
Added DTR Model 3700+ OPN.
hitechjb1 said:3000+: ADA3000AEP4AP 1.5V (C0 rev, F48h) <- ClawHammer, 512 KB L2, 2.0 GHz, x10 (512 KB L2 "disabled")
3200+: ADA3200AEP5AP 1.5V (C0 rev, F48h) <- ClawHammer, 1 MB L2, 2.0 GHz, x10
3400+: ADA3400AEP5AP 1.5V (C0 rev, F48h) <- ClawHammer, 1 MB L2, 2.2 GHz, x11
3000+: ADA3000AEP4AR 1.5V (CG rev, F4Ah) <- ClawHammer, 512 KB L2, 2.0 GHz, x10 (512 KB L2 "disabled")
3200+: ADA3200AEP5AR 1.5V (CG rev, F4Ah) <- ClawHammer, 1 MB L2, 2.0 GHz, x10
3400+: ADA3400AEP5AR 1.5V (CG rev, F4Ah) <- ClawHammer, 1 MB L2, 2.2 GHz, x11
3700+: ADA3700AEP5AR 1.5V (CG rev, F4Ah) <- ClawHammer, 1 MB L2, 2.4 GHz, x12
2800+: ADA2800AEP4AX 1.5V (CG rev, FC0h) <- NewCastle, 512 KB L2, 1.8 GHz, x9
3000+: ADA3000AEP4AX 1.5V (CG rev, FC0h) <- NewCastle, 512 KB L2, 2.0 GHz, x10
3200+: ADA3200AEP4AX 1.5V (CG rev, FC0h) <- NewCastle, 512 KB L2, 2.2 GHz, x11
3400+: ADA3400AEP4AX 1.5V (CG rev, FC0h) <- NewCastle, 512 KB L2, 2.4 GHz, x12
SunTzu69 said:Before I order, am I understanding correctly that there are no 2.2Ghz "CO" revision 3200+ A64's. All stock 2.2Ghz 3200+ are "CG" to date (for desktops).
I just want to confirm.
Thanks
from above article said:“The new strained silicon process, called Dual Stress Liner, enhances the performance of both types of semiconductor transistors, called n-channel and p-channel transistors, by stretching silicon atoms in one transistor and compressing them in the other. The dual stress liner technique works without the introduction of challenging, costly new production techniques, allowing for its rapid integration into volume manufacturing using standard tools and materials.”
above article from infoworld (12/13/04) said:...
As it has become more difficult for chip companies to improve transistor performance by simply shrinking transistors, they have turned to alternative techniques to keep improving the performance of their products. Strained silicon is a technique in which a lattice pattern of silicon atoms is either stretched or compressed to improve the speed at which electrons flow through the silicon. Positive transistors run faster when they are compressed, and negative transistors run faster when they are stretched.
However, strained silicon also works in reverse to the detriment of the transistors. Compressing the silicon atoms reduces the performance of negative transistors, while stretching the silicon impedes the performance of positive transistors, said Nick Kepler, vice president of logic technology development with AMD.
In order to get optimal performance from each type of transistor, IBM and AMD created the compressive strain on the silicon wafer with a film of silicon nitride and then removed the film from just the negative transistors, said Lisa Su, vice president of technology development and alliances with IBM. The companies then created the tensile, or stretched, strain on the wafer and removed that layer from the positive transistors, allowing both types of strain to exist side-by-side on the companies' chips, she said.
The companies believe that by using their strained silicon techniques on both positive and negative transistors they can improve transistor speed by as much as 24 percent, the statement said.
The strained silicon technology will be integrated into AMD's Opteron and Athlon 64 processors and IBM's Power processors in the first half of 2005.
IBM is planning to use the dual stress liner technology on all of its 90nm products starting next year, Su said. AMD will introduce the technology selectively on both 90nm and 130nm products next year and has already done so with the Athlon FX-55 desktop processor that was introduced earlier this year, Kepler said.
hitechjb1 said:PSU rating estimate for some 939 CPU and system
The 12V current rating of many existing PSU are
Fortron 530 = 18 A
In the long run, with lots of harddrives, optical drives, fans, ..., and if video card also uses 12 V (e.g. PCI-e supports up to 75W), then a typical system would take an additional 10-15 A (exact numbers have to be calculated based on hardware count and video card overclocking),
e.g. 4 HD's, 1 DVD, 1 DVD-RW, 4 or more case fans, 1 CPU fan, high end overclocked video card (if using 12 V)
12 V current rating = 13.2 + (10 or 15) = 23.2 - 28.2 A
from above article said:...
The enhancements include power reductions (gained by using slow but less leaky transistors in non-critical paths) and speed improvements (by using fast but leaky transistors in critical paths). Also, the processor halt and stopclock states have been improved, reducing some unnecessary work previously conducted during these states, resulting in a savings of several hundred milliwatts. Like the Pentium 4, future Hammer chips will feature on-die thermal throttling to cool themselves down if certain temperature limits are reached.
Performance-wise, the big news is the addition of SSE3 instructions, which accelerate a number of different types of computation, including video encoding, scientific computing, and software graphics vertex shaders. (For more on SSE3, see our Prescott review.) Beyond SSE3, the updated Hammer core will convert the LEA instruction, under certain circumstances, into an ADD instruction, which has only a single cycle of latency. AMD's design mavens have also added additional write-combining buffers to the chip, so it can combine up to four streams of non-cacheable writes, up from two. Hammer's data prefetch has been improved, as well.
