Hey anyone who has the board I'm just wondering if there is any way to set the vcore in BIOS or do I have to use jumpers?
And if I use jumpers, should I have it on ignore in the BIOS?
Antec SX1040B case
I modded it heavily
with dremel I cut out the front bottom face to fit in two 80MM Antec hydro sleeve fans
I then holesaw'd a 120mm Panaflo H1A blowhole on top...
6 - 80mm fans and 1 - 120mm fan total in the case.
For cpu heatsink I use the Coolermaster HHC-001 HEATPIPE... lapped of course with automotive sandpaper 180grit and AS3 grease.
the chip temp is heavily based on ambient which it usually is 11-12F above case temps so I have had same setting as low as 87F on chip full load and as high as 109F on chip full load - living in the desert is rough!!!
but Panaflo is the ONLY case fan to use! www.caseetc.com has a great deal for them.
