A7n8X Del rev 2.0
gtsimmo
Los Angeles, CA
Ok i tried a bunch of times to flash this bios and it just wont do it! Im really getting annoyed, actually i been really annoyed for awhile now. Im stuck with the 1003 bios. Anyone else have this problem? I tried Awdflash and it doesnt work. It gets to the point where it ask you to confirm you want to flash and than nothing. Is there anywhere i can order a new Bios chip pre flashed with 1004?
gtsimmo
gtsimmo
Los Angeles, CA
OMG i feel so stupid. I was looking without very much success for the windows based flashing program because from the threads i read it was the only alternative to the dos awdflash, i looked like crazy on the web for it just to discover it was on the CD that came with the mobo. DUh! Hehe
I never used the CD seeing how i always download the newest drivers straight off the net.
Roadkill
Regina, SK Canada
I have the same problem with my board. I can not flash in DOS. I have done many (50+) from windows on Asus boards and never had any problems.
Nolo31
Sheboygan Falls
worked fine for me. Alt + f2 at post screen, make sure you ahve the correct files on your dos bootable disk, and away you go. Not hard at all.
