- Nov 5, 2003
- Vancouver Island, Canada
For Overclocking, should this be set at auto or 66 or ...?
cheers
cheers
mfjonny said:The whole point of having AGP/PCI lock is to avoid having to alter those settings - meaning changing the settings from 66/33 to anything else leads to vid/HD/PCI corruption.
So yes, leave it on AUTO or 66 and don't set it to anything else. (Hangten, i'd recommend ditching the measly 500 pt gain and setting yours back to 66 as well. OCing your vid card has nothing to do with changing AGP bus speed and you should stick with upping IQ/mem speed of the vid card alone).
About your 3dmark crashing, have you tried running Prime95? Its a very good proggy to test stability and I would highly recommend it... If you are having problems with Prime and 3dmark, then I would venture to say that your rig is not quite stable and requires a tad more tweaking (or part adjusting).
Here's a link...
http://www.mersenne.org/freesoft.htm
hangten said:
My Radeon 9700pro is overclocked using the Omega Drivers set at 366/317 and stable but whats the wrong in running higher agp/pci? Back in the day of KT266 chipset I was always told that running the bus faster than 133FSB would overclock everything and that goes for the video card as well.I'm aware that even a divider did not exist on the MSI board i was running back then. I sure loved unlocking my pally and running it with a mad overclock of 100mhz or over (1533mhz to 1686mz) not bad for a chip that was called an XP Athlon. Remember standing in line on the first day Fry's Electronics sold them.
I'm running RAID as well but no file corruption even when going as high as 78 but my harddrives(Seagates 80gig SATA) benches increase as well.Just always room to learn from people. I can also run past 220fsb but at a CL of 2.5 (corsair pc3500 512) but figure tighter is better. My vdimm is modded as well as vcore and vdd on my rev2.0. Just pointing out what i have and my own set up and not to say this is concrete but each his own and if you like it and it works great.
This can help others understand the BIOS and alot moreIF YOU ENJOY LEARNING my fragile little mind is melting
