What are safe temp range for this board using 900 tb . I am using Asus pc probe in windows not sure the temps are accurate. I get cpu 49c and mb 32c under load room temp 25c
Harry (Jul 12, 2001 12:05 a.m.):
Asus Probe is notoriously inaccurate often by 7-10C high. To check, observe the reported temp, reboot to bios check the temps reported there, compare the 2. If there is a discrepancy of more than a couple degrees, dump Asus Probe and load Motherboard Monitor which can be found here. http://www.tweakfiles.com/diagnostic/motherboardmonitor.html
Your temperatures are OK not really great and a bit warm but not hazardous.
