On the A7V do you guys recommend just removing the green hs from the chipset, applying thermal paste and then putting the hs back on, or mounting a hs/fan in place of the stock hs? Also if the hs/fan route is better will thermal tape suffice or should I use something else?
thanks in advance
thanks in advance
