S
Sizzler
Guest
I just did my first OC with limited success and I would appreciate any of your ideas.
My A7V is Rev. 1.02 with the 1004d BIOS. I have a locked TBird 850 (thought about OCing a little late) connected to an Alpha PAL6035 w/ 26 cfm fan and Ultra Silver paste. Also: 256MB Micron PC-133, DiamondMax 40 HDD, Prophet II MX, & Live Value Sound. I used a jumper setting of CPU-105 MHz/PCI-35MHz and left the voltage at the default 3.56V. My Windows Me would run fine, but the system frequently locked up on games (to a lesser extent at CPU-103/PCI-34.33). Can I OC with stability without trying to remove the CPU to unlock it? If I do unlock the 850, does it OC well? What difference can I expect? My CPU temp is usually about 49C. Is that OK? What number do you like to stay under? Thanks a lot (from this beginner) for any help.
